E-brake light flashing
Old Jun 21, 2021 | 04:21 PM
BigBlueGa's Avatar
BigBlueGa
Default E-brake light flashing
'06 Mega Cab 4x4. So at random times the e-brake flashes and dings. It may come on once or twice on a 20 mile trip and then it may be a few days before it comes on again. When I changed the front brakes, I noticed uneven wear on the passenger side pads, so I changed out the flex line and caliper hoping this would solve the problem. It did not. Anyone have this problem? Any advice on a fix?
Thanks
Old Jun 21, 2021 | 04:56 PM
E-brake operates on the rear brakes. Might be a bad switch, or just out of adjustment.
Old Jun 22, 2021 | 08:57 AM
BigBlueGa's Avatar
BigBlueGa
Probably should put this in original post. The reason I went through all the changes on the front brake was I read that the light could come on if it sensed low fluid or uneven pressure on the brakes. I don't know if this is true or not. Anyone know?
Old Jun 22, 2021 | 11:28 AM
vietti2's Avatar
vietti2
may have got air in the anti lock brake pump . .need a professional scanner to do a brake bleed. to get it out..
here is the cheapest one for the job. its total china junk . made like crap but it does work
https://braydentechs.com/dodge-jeep-...vel-scan-tool/
