Tire
Old Jul 8, 2021 | 10:17 PM
Wvtruckman's Avatar
Wvtruckman
Default Tire
Tire rubbing on upper control arm on driver side
how do i fix it
Old Jul 8, 2021 | 10:36 PM
What are you driving? Stock size tires?
Old Jul 9, 2021 | 06:51 AM
jrsick's Avatar
jrsick
Tire size is good question.
When did you first notice the rubbing? Was there no rubbing for years then suddenly starts rubbing recently?
I'd jack the truck and check that wheel for play with no load on it. Particularly checking for bad wheel bearing, ball joints, or loose lug nuts. I recommend against driving the truck until you are certain there is not a safety issue.
Old Jul 9, 2021 | 07:23 AM
how do i fix it
Easy! Remove the tire!
