Howling from driver side door
Old Jul 10, 2021 | 09:37 AM
MythX's Avatar
MythX
Default Howling from driver side door
Hi everyone. I think I have an issue with the way my driver door is installed. It doesn't happen every time, but if there's a cross wind while I'm cruising down the freeway, I get a horrible howling sound from the driver door. It's extremely loud.
I've adjusted the latching mechanism to make it close tighter, but it had already seemed to be adjusted it's tightest. The foam seal around the door is in excellent shape. The noise seems to come from the top of the door. One of the things I noticed is that the driver door sites about 1/4" higher than the passenger door.
Is it likely that adjusting the door to sit lower (like the passenger door) would solve this problem? Is that something I should be able to do myself?
Thanks in advance.
Truck is a 2008 Quad Cab SXT 1500 4.7
Old Jul 10, 2021 | 09:41 AM
Adjust the door so that the body lines line up, and latches relatively tightly. (but, not too tight....) See if that improves things. Sometimes, for air leaks around the window frame, you need to actually bend the frame in more toward the body, so it will actually seal.
Old Jul 10, 2021 | 09:57 AM
MythX's Avatar
MythX
Thanks for the reply. Where is that adjustment made? Do I just loosen the hinge where they bolt into the body?
Old Jul 10, 2021 | 11:14 AM
Yep. Getting doors properly aligned is more of an art form..... To me, it's almost worth it to pay a body shop to deal with it.
Old Jul 11, 2021 | 02:15 AM
master tech's Avatar
master tech
Site Moderator & Tech
You can also use baby powder and put the powder around the door seal and close. Open the door and you should be able to see the gap.
