New motor won't start
Old Jul 11, 2021 | 01:06 AM
glenmoudy's Avatar
glenmoudy
Default New motor won't start
Put in new longblock , I have no codes new cam and crank sencers turns over but no power to coils or injectors
Old Jul 11, 2021 | 01:37 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you check the IPM or TIPM module for any blown fuses? Did the long block come with camshaft and timing already setup? I have seen where a connector under the dash on the driver side would come loose and unplug and that will also cause a no start problem. But these are just guesses without seeing the vehicle.
Old Jul 11, 2021 | 01:56 AM
glenmoudy's Avatar
glenmoudy
Yes check all fuse checked under fuse box for cracked wires check all grounds
Old Jul 11, 2021 | 02:04 AM
glenmoudy's Avatar
glenmoudy
Old Jul 11, 2021 | 02:12 AM
master tech
By any chance did the wire harness get pinched while installing the motor?
Old Jul 11, 2021 | 04:30 PM
glenmoudy's Avatar
glenmoudy
Thought of that also and no .I don't get that I have no codes
Old Jul 15, 2021 | 11:23 PM
glenmoudy's Avatar
glenmoudy
So nothing ,no body's got a clue it was just a head gasket motor had 200,000 so thought to put a fresh long block and it been a night mare and from read others this is something that happens often.
Old Jul 15, 2021 | 11:33 PM
master tech
I'm running out of options, Turn the key on and try to jump the starter relay. If you are not getting any power out to the engine. I'm guessing ignition.
