AC Dont blow
Old Aug 13, 2021 | 08:50 PM
oppdrandy's Avatar
oppdrandy
Default AC Dont blow
Today my 2002 Ram 1500 had an ac issue. It was working great as usual blowing really good cool air. Stopped at a local establishment and AC was not blowing at all. Drove about 100 yards and it started working again. Any ideas?
Old Aug 13, 2021 | 11:55 PM
Alex Medeiros's Avatar
Alex Medeiros
AC condenser fan might be toast. It's a common issue with these trucks.
Old Aug 14, 2021 | 12:03 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Dead giveaway condenser fan. Stopped there's no airflow = no heat transfer. Start moving and airflow cause heat transfer to happen.
Old Aug 14, 2021 | 08:43 AM
Was the a/c not blowing any air at all? Or was it blowing warm air?
Old Aug 14, 2021 | 09:02 AM
Dodgevity's Avatar
Dodgevity
Sounds like a bad blower motor or resistor.
Old Aug 14, 2021 | 03:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
These model did have a condenser fan next to the radiator. Check the fuse first and see if it is blown. If it is the fan has a short and is causing the fuse to pop. I think the fuse is #13 or #23.
Old Aug 15, 2021 | 08:22 AM
ole buck's Avatar
ole buck
Turn on ac and fan to wide open. on the passenger side floorboard right above where your right foot would rest is the blower motor. strike it on the bottom with a few good blows. mine did something similar to this, a/c running but no air moving. a few bangs on the blower motor and kaboom !!!! cold air started blowing. hope this helps I am a dodge ram noob by the way so this might be miles away from your issue.
