2004 Dodge ram 1500 slt 4.8l v8 quad cab 4x4
Old Oct 3, 2021 | 02:51 AM
Prismatic's Avatar
Prismatic
Originally Posted by Jeff0172
it drives great it takes bumps and pot holes better then my saturn vue shockingly the handleing is great the front does pull to the right slighly when i go above 70...yes that was the plan when i got it was to remove the lift kit because my son is only 6 months old so i didnt want my wife haveing to climb in and out with my son till my wife seen it and wanted the lift kit to stay..lol any advice on what should be replaced if i keep the lift kit òn?ot anything you think i should switch or swap out without reduceing the ride height?
You're not removing the lift kit without the original spindles to put back on.
Old Oct 3, 2021 | 06:46 PM
Jeff0172's Avatar
Jeff0172
new leaf springs it is lol
Old Oct 6, 2021 | 10:11 AM
rtmtrrdr's Avatar
rtmtrrdr
You posted that it’s a 4.8l I think you meant 4.7l. If so keep very good maintenance on it. Oil change,coolant level, ect. 4.7’s don’t like to get hot. Usually takes 1 time of it happening and the motor is toast. I’ve got 217000 on mine and I’m very meticulous about oil changes and such. The other thing to look out for is the timing chain guides. They usually don’t last past 100000, it’s a pia to do and I had to have someone do mine.
Old Oct 6, 2021 | 08:21 PM
Jeff0172's Avatar
Jeff0172
yes 4.7l the motor is at 182k miles atm the orginal owner said he kept up with oil changes (but you know how that goes) i chexked the oil and it looked lile it was just changed but i dis find a bunch of lucas oil stablizer emptys in tge bes of the truck so i hope he didnt put that in im going to change the oil and coolant just to be sure..what color colant should i use? It was bought from a dealer at 170k miles and the second owner only put 11k miles on it the chassis is in very good shape and it looks like at some point the cab was swapped out there no ruat underneath and whats on the chassis and suspension is just sutface rust so if the motor does end up going i plan on doing a hemi swap a new fuel pump was just put in also
This is under the cab
Old Oct 7, 2021 | 07:15 AM
jrsick's Avatar
jrsick
I see a traction bar installed. I rec you do some research on traction bars and why they are used. Given the bent leafs and traction bar, I suspect your truck did some heavy towing at some point.
Have you opened up the rear diff and taken a look? It couldn't hurt to change the diff fluid, and you can also see if you have open diff or anti-spin (aka posi trac, LSD).
Old Oct 7, 2021 | 08:22 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
That's not a traction bar lol, that's up front (you can see it parallels the torsion bar). I mean, you can see the two oil pans lol. There isn't anything on the leafs.
Old Oct 7, 2021 | 08:41 AM
jrsick's Avatar
jrsick
oops, you are correct. Do you know what that red bar is for?
Old Oct 7, 2021 | 01:31 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
I'd say it's some kind of brace, it looks like it might be designed to pivot where it's attached to the front cradle but I don't know what the other end goes to or why. Literally looks like it goes from the T-bar crossmember to the cradle and parallels the T-bars.
Old Oct 7, 2021 | 03:44 PM
Prismatic's Avatar
Prismatic
They're kicker bars, designed to resist the rearward movement of the front cross member on shock loads. By bolting a new front cross member onto the existing cross member, you've introduced a torsional component the factory mounts weren't designed for. They bolt from rearward front cross member to the transmission brace.
Not necessary under normal driving conditions but if you go off road, hit a curb in the snow, tag a rock, etc, the shock loads from the extra 5 inch drop could cause frame issues.
Old Oct 7, 2021 | 03:55 PM
Jeff0172's Avatar
Jeff0172
There are 2 red bars total on for the front end and the big one going from the transmission to the rear of the truck ill take better pics in a few its raining right now but i was woundering what those where because it didnt look stock to me the last owner said all the suspension wotk was fone in a shop in ky but wasnt sure ahat was done other then tge lift kit and a body lift kit but i def plan on looking at the rear diff i just have to get a new floor jack mine wont lift the truck safely
