Oil Pressure drops
Old Oct 16, 2021 | 01:37 PM
David Petrie's Avatar
David Petrie
Default Oil Pressure drops
I have a 2008 Ram. I just had the heads replaced and now the oil pressure gauge is dropping at stop lights. Upon acceleration the pressure rises to normal and everything is fine except for this minor issue. Thanks for all suggestions in advance
Old Oct 17, 2021 | 09:54 AM
Replace the oil pressure sensor.
Old Oct 18, 2021 | 12:37 PM
jrsick's Avatar
jrsick
If you have one of the large auto parts stores nearby, consider getting a mechanical oil pressure gauge as a loaner tool.
Are you hearing any valve clatter?
Oil level is correct viscosity and proper fill level?
I agree that new pressure sensor is good first step.
