03 ram 2500 5.7 hemi 5speed throttle sticking?
Old Oct 27, 2021 | 05:40 PM
03ram5speed's Avatar
03ram5speed
Default 03 ram 2500 5.7 hemi 5speed throttle sticking?
well fellas just when I thought I had everything fixed, new wheel bearings, broken ground, and busted leaf springs here I am again..... so the truck has done this intermitally in the past but it always went away so I figured it was a computer issue. BUT it seems as thought my throttle is sticking. when I shift (5 speed Manual) the rpms do NOT drop at all to the point if I want them to drop I have to hit the brakes to make them drop. i also came to a light and the rpms hung up around 15-1700 rpm until I came to a full stop and then the rooms finally went down. I have cleaned the throttle body also checked for air leaks and nothing. any help is appreciated.
Old Oct 27, 2021 | 10:20 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have a throttle cable or is fly by wire?
Old Oct 28, 2021 | 12:36 PM
03ram5speed
Default I
have a cable coming off the pedal.
Old Oct 28, 2021 | 01:16 PM
master tech
I believe there was a recall for the throttle cable. But not sure, I would take the cable off at the throttle body and move it by have and see if it sticks. And do the same with the pedal and cable. You may have a sticky pedal or cable.
Old Oct 28, 2021 | 01:54 PM
03ram5speed
see this is what has me confused. the throttle body anly has wires running to it? the cable from the pedal goes .... well I don't know where but yes the pedal is very stiff to push and it seems to stick so I'm not sure as to where to start.
Old Oct 28, 2021 | 02:13 PM
Throttle by wire. The cable from the pedal goes to a sensor somewhere. Follow the cable, and you will find it.
Old Oct 28, 2021 | 02:25 PM
master tech
Okay the throttle position sensor has 3 wires going to the sensor on the throttle body, but you need a lever to change the position of the sensor. The new Ram trucks have Fly by wire. No Cables. The Fly by wire system has an apps system no cables. So if you don't have a cable on the the back of the pedal (Gas) then you don't have a fly by wire system.
Old Oct 28, 2021 | 02:53 PM
03ram5speed
ok I'm going to go trace the cable from the pedal and see where it leads to see if anything is hanging up, appreciate all the help with this thing!
Old Oct 28, 2021 | 05:59 PM
03ram5speed
Soo I lubed the cable up and the pedal is a lot smoother. also acts as it should setting still rpms drop immediatly ,BUT it still acts as though it's sticking when I'm in motion and push the clutch in. any other ideas?
Old Oct 29, 2021 | 12:45 AM
master tech
I know the Dakota trucks do the same with clutches. My son truck does the same, Just make sure you don't have any vacuum leaks. And if it idle comes down after a few seconds. I wouldn't worry about it.
