Ignition on for Radio
Old Nov 24, 2021 | 08:19 PM
ThomasB's Avatar
ThomasB
Default Ignition on for Radio
Just bought a 2003 2500 RAM, very happy with it...
There is a issue with the radio though.
The Ignition Wire BLK/RED (which turns radio on and of) has Power when Iginition and Motor are on. No Power when key is in middle position, AND POWER WHEN NO KEY IS INSERTED.
That means my radio is always on when parked, it drains the battery.
The cigarette lighter has the same effect. it is always on, only when key is in middle position it's off.
I think that a previous owner modified the ignition wire?
There is an aftermarket alarm/ remote key look where I have no fob for installed, maybe that is the problem?
Here are my questions:
How can I get the car back to the factory condition?
Which other wire could I use for Igniiton on?
Thomas
Old Nov 27, 2021 | 09:02 PM
racerxv6's Avatar
racerxv6
ThomasB, sounds like you are going to need manual for your year and do some investigation on your wiring harness.....The mods on here are good about knowing where to go to obtain one wish I knew where to go for ya......
Old Nov 28, 2021 | 06:36 AM
95RAM360's Avatar
95RAM360
This happened when I put aftermarket radio in, I ran a new wire from the power to a blank fuse that’s only on when key is on, problem solved
Old Dec 9, 2021 | 11:16 PM
ThomasB's Avatar
ThomasB
I found a wire from alarm, that has 12v only when car is in ignition and run and used that.
Still strange that the right wire doesn't do what the manual says, it is hot when key is in off position...
