2007 Dodge ram 1500 ignition lock cylinder
So I've had an issue over a decent amount of time where my key wont turn in my ignition but eventually after about 2 tried it will go in. Well today it turned just fine in the morning but at lunch it decided to absolutely not turn. So I spent 2 hours trying everything I possibly could to either remove or just turn the ignition. I believe it's a stuck pin and I was planning on replacing the lock cylinder. The only issue is I can't turn the key which means I can't push the release pin on the bottom of the mechanism to pull out the cylinder. Any ideas on what I should do. I have watched over an hour of yt videos just trying to figure something out. This is basically my last ditch effort before I call a locksmith to try and take a crack at it.
