3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello all, can someone tell me why these lights are on? When do I connect to my scan device it tells me the code is not in the database? However, there is no update yet. Why are they on?
Well, I want to say thank you all for the advice. I changed the ABS sensor and that did the trick. Everything is working now. I also changed the shocks will I was under there.
