Power outlet not working
Old Dec 29, 2021 | 02:06 PM
Cliffh's Avatar
Cliffh
Default Power outlet not working
2008 1500 quad cab w/5.7
For the first time, I used a 12v air compressor (plugged into the port on the dash under the radio) to put ~20psi in one of the tires. It ran for maybe 5 or 6 minutes. The wiring for the compressor was warm, not hot. It was running when I shut it off.
Now the power port on the dash doesn't work.
I've checked the #1 fuse in the box under the hood, fuse looks good. Replace it with a known good fuse, port still doesn't work.
What else can I check?
Old Dec 29, 2021 | 11:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Pull out the power port and check your wires for power and ground. You could just have a bad port.
Old Dec 30, 2021 | 06:30 PM
Cliffh's Avatar
Cliffh
I've got to check the switch for the rear window, which is right next to the port. Two birds with one stone.
Now, if I can just make the time....
The panel should just pop off, right?
Old Jan 16, 2022 | 08:46 PM
Cliffh's Avatar
Cliffh
Don't know what happened, but when I got in the truck this morning the port was working again. I'm guessing there's either a loose or corroded wire involved. One of these days I'll get to looking at it - as honey-do's and doc appointments allow....
