Error Codes 0302 0402 0068 0404
Old Jan 13, 2022 | 10:33 AM
siclamb's Avatar
siclamb
Default Error Codes 0302 0402 0068 0404
Hey everyone, I'm new here on this forum and wanted to introduce myself before I ask a question. My name is Simon, I'm from Texas and I love working on my truck and cars. I inherited a 2005 1500 Ram and I just replaced the whole front end suspension.
The CHECK ENGINE LIGHT is on since I got it and can't figure out what the cause is. I get the following error codes P0302, P0402, P0068 and P0404.
I would love to fix this and enjoy driving it a while longer!
I appreciate and thank you for your advice and opinions!!!
Old Jan 13, 2022 | 01:13 PM
jrsick's Avatar
jrsick
I recommend you start with the 0302, that's a misfire on cylinder 2. You don't mention if you have a 4.7 or 5.7, but examine the plug(s) from cylinder 2. Also make note when removing the plugs if they are properly torqued and not loose.
Spark plugs will tell you a lot about what is going on with the engine. There are good videos on spark plug analysis.
Old Jan 13, 2022 | 03:54 PM
siclamb's Avatar
siclamb
It's a 4.7. I replaced all the Spark plugs 3 months ago because I thought this was the issue. Aside from the age of the plugs, they looked decent
Old Jan 13, 2022 | 05:50 PM
What brand plugs did you install? What type?
Old Jan 13, 2022 | 06:23 PM
siclamb's Avatar
siclamb
I installed NGK pro-v
Old Jan 13, 2022 | 09:02 PM
Are those platinum, or iridium, or someotherium?
Old Jan 13, 2022 | 09:16 PM
siclamb's Avatar
siclamb
Old Jan 14, 2022 | 10:34 AM
Ok, good ol' copper plugs.
Some interesting codes there...... Do you have a scanner that can read live data??
Old Jan 14, 2022 | 01:03 PM
siclamb's Avatar
siclamb
I used that brand for years, do you have reservations against NGK regular ol’ copper?
Erased the codes last week and took a fresh reading just now. The only code popping up is P0420
Old Jan 14, 2022 | 01:33 PM
That code is for the cat...... Might try removing the front O2 sensor from the exhaust completely, and see if the truck runs any better.
