(NO HEAT) 06 Dodge Ram 1500 quadcab
Old Jan 23, 2022 | 09:04 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by ykkyle
yes both heater hoses are hot
Originally Posted by jrsick
I'm leaning toward heater core air pockets (or leak), but I think you would have a temp problem with your engine if this was the case, so I'm not certain. It sounds like air is being directed properly, it's just not warm, and that makes me think heater core problem or switch.
If both heater hoses are hot, that tells me the heater core has hot coolant flowing thru it. This sounds like a blend door issue.
Old Jan 23, 2022 | 10:26 AM
It may have coolant flowing thru it, but, if the air pocket is large enough, not enough of the core will transfer heat to the air passing through it.
Old Jan 23, 2022 | 06:15 PM
ykkyle's Avatar
ykkyle
I am thinking its a blend door issue because the black box behind the glove box gets warm to touch.
I found this video on youtube and I am pretty sure this is the problem
Old Jan 24, 2022 | 09:28 AM
Dodgevity's Avatar
Dodgevity
One hose would be cooler than the other though, or both wouldn't be hot. If both are hot, that's almost a sure thing that the heater core is working. OP wouldn't be saying this....
yes i am getting VERY cold air and it does flow out of all vents
Old Jan 24, 2022 | 06:09 PM
If the core isn't transferring the heat away from the coolant, the air will be cold, and both hoses will be about the same temp. Of course, if the blend door is broken, you would get the same symptoms.
