03 how do i remove the main ecu connector? bolt spins
Old Feb 12, 2022 | 03:41 PM
CamaroMan's Avatar
CamaroMan
Default 03 how do i remove the main ecu connector? bolt spins
how on earth do u remove the main ecu plug? ive gone through every other plug - cleaned anti corrosion and installed just cant get this one to budge-
im chasing an APPS issue, sensor tested fine, live data still shows APPS spikes and random flat tops indicating a bad wire somewhere...
Old Feb 12, 2022 | 11:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Are you working on a Diesel or Gas. If the bolt or screw is just spinning, the threads maybe striped. When I remove connectors, I will spray them down with soapy water. No WD40.
