Coolant leak
Old Mar 25, 2022 | 08:05 PM
Matthew7777's Avatar
Matthew7777
Default Coolant leak
I have a coolant leak in the front of my 08 dodge ram 1500 4x4 5.7 hemi its leaking onto the cross member so I don't know where it is coming from im thinking water pump but not sure needing some help to figure it out it doesn't get hot it runs good and stuff like that don't have any pictures right now sorry
Old Mar 26, 2022 | 01:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
I would pressure check the cooling system and see if the water pump is leaking or a hose.
Old Mar 26, 2022 | 07:42 AM
Dodgevity's Avatar
Dodgevity
You can rent the pressure tester (free when you return it) from any auto parts store. It allows you to find a leak without the distractions of heat, noise and moving parts. Pump it up to the PSI on your radiator cap, get under the truck and wait...
Grab your rad fan and rock it back and forth, towards and away from you. If any play, the water pump bearings are shot. Also if leaking, you should be able to see the white building/markings on/around the pump.
Old Mar 26, 2022 | 12:44 PM
jrsick's Avatar
jrsick
Concur with previous comments, good advice.
Coolant dries to a white film. Look around your engine bay, particularly black hoses and the Hemi cover, and see if you can find a spray pattern.
Also visually check your radiator fins, it's easy to see if you have bulges or distortion in the passages.
Take a look all around the top of your water pump, do you see coolant pooled there? Black light flashlights are cheap, and coolant will glow under black light.
Pressure testing is best option, just giving other areas to look.
Old Mar 28, 2022 | 07:56 AM
fj5gtx's Avatar
fj5gtx
I keep having a small leak at the water pump, but can't ever locate exactly where it is. The previous owner had a newer one on the truck when I bought it... I put a brand new one on it, same problem. I'm wondering if one of the bolts goes through the water jacket and needs sealant on it when you thread it in. [ 2004 5.7]
Here is my thread from when I replaced the radiator. Thought I had it fixed, but noticed its leaking again... argghh!!!
https://dodgeforum.com/forum/3rd-gen...ting-seal.html
