04 Dodge Ram 1500 5.7L 4x4
Old Mar 30, 2022 | 11:02 PM
2319_john's Avatar
2319_john
Default 04 Dodge Ram 1500 5.7L 4x4
Hey guys, I need some help I have a 04 Dodge Ram 1500 5.7L 4x4 with a 8ft long bed. Piston 6 blew up and did a new motor swap . I ordered a new 5.7l crate redesigned motor from Powertrain products , I swapped all sensors and ordered new parts that were damaged or worn out from the old motor to put on the new motor. I got everything hooked up but I’m kinda hesitant on starting the motor since I need to build oil pressure first before I start it up . I need help on what’s the best way to build up oil pressure on my new motor without starting it first , and will my motor start up or will I need to reset my Computer to make it work with the new motor? I appreciate your time to read and help me thank you
Old Mar 31, 2022 | 07:04 AM
Disable the fuel pump, or coils, and crank the engine to build oil pressure.
Will it start? Don't know.
Old Mar 31, 2022 | 07:14 PM
fj5gtx's Avatar
fj5gtx
If its pretty dry, you may want to try this method...
Old Apr 6, 2022 | 05:56 AM
95RAM360's Avatar
95RAM360
I did a hemi swap not to long ago in a 06 jeep commander….I just started it, let her rattle for the 5-6 seconds and it was good, built oil psi quickly
