Frame rotting out.. no fix?
Old Apr 12, 2022 | 03:39 PM
jeffkrol's Avatar
jeffkrol
Default Frame rotting out.. no fix?
Well my frame has a big rust hole at about half way between the tires.
Had took the truck in for a completely unrelated issue. See antifreeze lost post of mine.
Apparently frame rot in trucks of all makes and even newer ones have an "issue" with this.
Any advice besides a new truck?
Old Apr 12, 2022 | 04:13 PM
If there is a big hole in the frame there, likely the rest of the frame ain't in the best shape either..... Swapping it out is a fair bit of work. Even if you could find one in decent condition. Most shops won't fix the frame......
Old Apr 12, 2022 | 10:40 PM
fj5gtx's Avatar
fj5gtx
There are welding shops out there that fix frames. I'd shop around and see who can do it. I had a 1976 Pontiac Ventura fixed back in the day, he did a good job and that car lasted a long time.
Old Apr 13, 2022 | 12:56 AM
jeffkrol's Avatar
jeffkrol
yea that's not happening..but thanks
Old Apr 13, 2022 | 12:58 AM
jeffkrol's Avatar
jeffkrol
Yes, checking now.
Also new trucks..
Old Apr 13, 2022 | 06:11 AM
95RAM360's Avatar
95RAM360
I do frames at my shop, I’m a certified welder. I’ve done many many frames and some that are real bad…there’s always a way to fix it’s just how much are you willing to spend
Old Apr 13, 2022 | 12:28 PM
jeffkrol's Avatar
jeffkrol
Well you gave me some hope. Not worrying about the cost atm. Guessing it is cheaper than a new truck..
