Highbeam plug
Old Apr 30, 2022 | 07:45 PM
Kramsay7's Avatar
Kramsay7
Default Highbeam plug
Hello, my father had unplug my highbeams, he said it was a plug.. I’m wondering where it is I’ve looked n haven’t been able to find it. He’s not around right now n he forgets where it was located.. anyone know?
Old May 1, 2022 | 08:16 AM
jrsick's Avatar
jrsick
What vehicle do you drive?
Old May 1, 2022 | 01:29 PM
Kramsay7's Avatar
Kramsay7
2007 Dodge Ram 1500 reg cab short box
Old May 1, 2022 | 03:55 PM
It'll be in the same harness as the low beams, just follow that one back, and look for a branch.
Old May 1, 2022 | 07:22 PM
jrsick's Avatar
jrsick
So we are talking same thing; there is a single headlight bulb that serves as both high and low beam. There is a single harness that plugs into the bulb. Unplugging the bulb would result in the headlight not working at all.
I guess what happened here is that the high beam wire was isolated and cut. You would need to splice the cut wire to get high beams working again.
Let me know if I'm missing something.
Old May 2, 2022 | 06:07 AM
Kramsay7's Avatar
Kramsay7
He said he never cut anything, he just unplugged something.. my low beams work, highbeams don’t.
Old May 10, 2022 | 06:13 AM
95RAM360's Avatar
95RAM360
I would check the fuse…..do you have the “lamp out” message?
when my high beams went out I had to replace the fuse box/fcm which is pretty common to crap out
