2004 dodge ram 1500 SLT 5.7 HEMI
Old May 19, 2022 | 11:00 AM
Nomad530's Avatar
Nomad530
Default 2004 dodge ram 1500 SLT 5.7 HEMI
I have a 2004 dodge ram 1500 SLT 5.7 HEMI it has 234k miles on it and has been a good truck until recently I've noticed that sometimes it will loose Hp when I stop at a stop sign and I press the gas pedal and the rpms go up to about 3000 before it starts to move. Also when I'm driving down the road my truck will be at a steady speed and it acts like I hit the governor on it. So I was wondering could that be caused from the ignition coils going bad? the check engine light is on and the code is a P2311 and it says it's ignition coil D secondary circuit. Where can I find out what ignition coil it is?
Old May 19, 2022 | 11:06 AM
That would be cylinder 4. Test the coil. Welcome to DF! Moving this to third gen ram section for ya.
Old May 19, 2022 | 11:10 AM
Nomad530's Avatar
Nomad530
Default How
How do I test them?
Old May 19, 2022 | 12:04 PM
Nomad530's Avatar
Nomad530
Default Another ?
So would the ignition coil being bad cause it to loose horse power from a stop and make it feel like it's slipping while I'm driving down the road?
Could it mess with the shifting aswell?
Old May 19, 2022 | 12:07 PM
Swap the coil on 4 and 6. See if the code follows the coil.
Losing one cylinder will likely make it feel down on power. Don't know if that would also affect trans behavior.... One problem at a time.
Old May 19, 2022 | 12:17 PM
Nomad530's Avatar
Nomad530
Default Ok
Ok ill swap them out I am going to do that on Sunday and I'll come back on here if there are any more problems. Thank u
