Timing chain cover and water pump install bolt torque sequence
Old Jun 28, 2022 | 06:47 PM
Junkyard Junkie's Avatar
Junkyard Junkie
Default Timing chain cover and water pump install bolt torque sequence
Hi,
i can't seem to find this info. Anyone have a screen shot of this?
Thanks again.
Old Jun 28, 2022 | 07:38 PM
Is it in the service manual??
Old Jun 28, 2022 | 07:43 PM
Junkyard Junkie
No, not that I could find, but I've always had trouble with the PDF one's. Got everything else I need from it. Just not the cover.
Old Jun 28, 2022 | 08:19 PM
Look in the engine section, under timing chain R&R..... maybe something in there. I suspect torque sequence on the water pump bolts is relatively important, probably not quite so much on the cover itself.
Old Jun 28, 2022 | 08:51 PM
Junkyard Junkie
Looked again, nothing for either one. 5.7 engine section begins on pg 5761, if anyone else wants to give it a shot.
I agree the sequence here is important, but not covered? Can't be, right? No info found on-line either.
Old Jun 29, 2022 | 02:59 PM
If it is important, then I would expect they would cover it.... since they don't, I would just use the good ol' standard alternating pattern, like you do for lug nuts. Toque to spec, once they are all in there, retorque all of 'em, call it a day.
Old Jun 29, 2022 | 05:07 PM
fj5gtx's Avatar
fj5gtx
Not anything but a torque value in the 2004 service manual.
(1) Install water pump and mounting bolts. Tighten mounting bolts to 24 N·m (18 ft. lbs.).
Old Jun 29, 2022 | 07:07 PM
Junkyard Junkie
It's odd that there isn't a torque sequence for this but oh well.
And removal and install of the trany pan is equivalent to surgery. Needless to say, I didn't know about the removal sequence of the trany pan so I zipped that off without a second thought. Guess I'll have to wait and see if I warped it.
Thanks again.
