Dorman harmonic balancer not fitting
Old Jul 1, 2022 | 04:23 PM
Junkyard Junkie's Avatar
Junkyard Junkie
Default Dorman harmonic balancer not fitting
Hi,
I have a 2006 Jeep Commander with the 5.7L hemi. I'm trying to fit a Dorman 594-324 harmonic balancer, but it's not going on. I've been using a hammer and a seal driver, but stopped because it was not working out and I don't want to beat the snot out of it.
Do I have to have an installer for this?
Thanks.
Old Jul 1, 2022 | 04:37 PM
fj5gtx's Avatar
fj5gtx
2004 factory service manual says you need special tool (8512-A) to install it... Google that tool #, and you'll find people are saying they were able to loan it from chain parts stores.
File Type: pdf
Old Jul 1, 2022 | 05:46 PM
Junkyard Junkie
Thanks again.
I'll get it tomorrow if it's available.
Old Jul 8, 2022 | 06:18 AM
95RAM360's Avatar
95RAM360
Dumb question but you do have the key way properly aligned right?
Old Jul 8, 2022 | 06:38 AM
Junkyard Junkie
There's no keyway on the Hemi, just a press fit. I still haven't gotten to installing it, but will soon.
Old Jul 8, 2022 | 08:05 AM
Dodgevity's Avatar
Dodgevity
Just curious as I don't have a Hemi. With no keyway, how does it lock to the crankshaft? I can't image compression alone being enough to prevent it from spinning.
Old Jul 8, 2022 | 08:19 AM
Junkyard Junkie
Yes, it's weird. Took a bit to accept it myself, but that's how it is. Just a press fit. A very tight press fit, probably why it can't be installed without a tool.
Old Jul 8, 2022 | 08:56 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
This is why all the 3G-4G hemi blower kits require you to pin the crank; a nice fat key wouldn't require it lol.
