? on supercharger for hemi??
Old Jan 10, 2006 | 02:29 PM
05ramlaramie's Avatar
05ramlaramie
Default RE: ? on supercharger for hemi??
save up for tires instead....they will run you about 1k esp if you have the 20's!!
Old Jan 10, 2006 | 02:46 PM
Horseapples's Avatar
Horseapples
this is what i found on cams:
New XFI™ 5.7 & 6.1- Liter Hemi Camshafts COMP Cams®’ new XFI™ (Xtreme Fuel Injection) camshafts for Hemi-powered Chrysler vehicles dramatically increase engine horsepower and torque, yet retain compatibility with all OEM vehicle computer systems. Available in three different profiles (XFI™ 260, 268 and 273), the new camshafts are uniquely engineered for street performance and towing applications.
In recent dyno tests performed on a Chrysler Hemi engine (outfitted with COMP’s #26918 Beehive™ valve springs and upgraded exhaust), the XFI™ 260 camshaft netted 20 additional ft pounds of peak torque in lower rpm ranges and 31 additional horsepower. Stepping up, the XFI™ 268 camshaft added 14 ft pounds of torque at low rpm and 47 additional peak horsepower. Amazingly, COMP’s XFI™ 273 camshaft yielded it’s most significant horsepower increase (over 4500 rpm) generating 61 horsepower more than the stock Hemi 5.7-Liter camshaft.
Old Jan 10, 2006 | 02:48 PM
Horseapples
I got this info from Mancini Racing's web site
Old Jan 10, 2006 | 05:14 PM
05ramlaramie
....and hypertech and superchips claim gains of 15-20hp and 30lb/tq with a $350 programmer.......
not gonna happen.
you will see the high hp gains WAYY up top...like mentioned (above 4500-5k rpms).....but you arent seeing the amount posted unless you have every little supporting mod.....I doubt these numbers were acheived with cams only.
those #'s are probably in conjunction with intake,headers,high-flow cat, exhaust.
just like when a supercharger says up to 150hp gains.....(when used with intake,exhaust,headers,etc.)
so all in all...those cams alone are only giving you about 30-40% of what they claim.
Old Jan 10, 2006 | 06:50 PM
Horseapples
I contacted Comp Cams to find out the scoop.they told me the cam power claims were made on an engine dyno with headers on 89 octane gas,except the biggest of the 3 grinds,which was tested on 92 octane,They claim these were the only things done to the engine besides swapping valve springs,but i dont know,sure seems like alot of power for a 350$ cam,i would like to hear from someone that has one of these to see if they really work as advertised
Old Jan 11, 2006 | 09:42 AM
hemifever's Avatar
hemifever
SPONSOR
If I'm not mistaken, those cams dyno tests were also done on crate motors. Not engines managed with our truck pcms. Your best bet for a cam is to contact KRC so you can get the custom pcm tune that requires them to function properly when matched to a PCM.
And what was said above. Bigger cams mean your power curves slide to the right. You're not gonna put in a perf cam and get gobs of tq down low and gobs of power up high. You'll end up with low end loss and a much stronger pull up high. These trucks need gobs of tq down low for the hole shot. I'm dying to see the cam change ETs though. I saw one person lose .2 in the 1/4 with the 6.1 cam. Not sure if that was weather or traction aiding that loss. We need some more testings other than butt dyno's.
Old Jan 14, 2006 | 12:04 AM
hemi24s's Avatar
hemi24s
dont even bother with comp cams they have so many problems and they are constantly updating there bad work, i just ordered my cam from dodge, its off a 6.1 hemi and it only cost me 150.00
i have gone the other forums like dodgetruckworld.com & hemitruckclub and have spoken to guys who have had this mod done and say its great i have seen dyno charts with this cam and a couple other bolt ons like intake & exhaust and they were getting 61 rwhp putting them over 300 hp to the wheels and not even touching there springs retainers or pushrods ( even though they recommend it) i would def. recomend getting one from mopar. i tried a local dealership in san diego but they said its a restricted item but i know someone who can get them anyway who works at a dealership in texas. email me if you want his info.
MOPAR 4 LIFE!
