2003 1500 4.7l magnum stalling issue
Old Aug 5, 2022 | 11:37 PM
Imnewtomechanics's Avatar
Imnewtomechanics
Default 2003 1500 4.7l magnum stalling issue
Hello, I am new to mechanics and I'm having some unfortunate issues with my beloved ram, it's got this stalling issue where whenever I'm at a stop, it'll stall when I try to go, considering its an automatic, I doubt its my fault, unless I'm somehow that bad, but regardless, it'll start back up as if nothing happened. but still, I can't trust it to get me to work, I've tried a few things that may have caused it, I've replaced my battery, my 02 sensor, I've checked my grounds, my fuses, and I still can't seem to fix it, I'd love to scan a obd code but the computers are erased every time it stalls, the codes usually come back every 3 days after I'd erase them( I've had a code for the hvac for a while) I have a feeling it's a electrical problem but that's mostly outside my knowledge, again I'm practically new to auto mechanics, everything I k ow I've taught myself, which isn't alot, but I really don't want to sell it, and I don't want to take it to a mechanic to have twice as many issues when I get it back. Open to all suggestions
. Thank you for your help
Old Aug 6, 2022 | 08:21 PM
95RAM360's Avatar
95RAM360
Mine did this when my speed sensor went bad, except the difference was everytime I came to a stop it would stall, and my Speedo did work….went under and I had an exhaust leak that melted my speed sensor wires to the rear pumpkin….
but my truck has the 46re trans….
Old Aug 6, 2022 | 11:14 PM
lxman1's Avatar
lxman1
Site Moderator
Could be the TPS sensor having a bad spot on the rheostat causing it to send a messed up signal to the PCM.
Old Aug 9, 2022 | 07:39 PM
Imnewtomechanics
hey, i replaced my tps and it seems to be running better, i wont know till i take it to work tomorrow, that drive should give me good results, any clue why my rpms will fluxuate while in park? it'll dip from 1000 rpm down to about 700 before going back up to 1000, and itll keep doing that untill i throw it into drive.
thanks for the help
