Low oil pressure
Low oil pressure
Hey guys! I have a 2005 ram 2500 5.7 hemi with less than 130k miles. Going down the highway, humming along smoothly, suddenly the oil pressure drops to 0, no warning bells or lights, no CEL. Now I can’t get it to start, it tries to turn then kills a brand new battery. Any ideas? Thanks!
Take off the serpentine belt, see if the starter will crank the engine then. If not, then try and turn the engine by hand...... Can you? It's possible your oil pump failed, or something similar, and the engine is just locked up.... If the starter "thumps" nice when you turn the key, but won't roll the engine over, that is NOT a good sign.
Trending Topics
Almost anything 'can' be fixed.... it just might be more expensive than a new motor.
If the pump did fail, and the engine is indeed seized, I would be much more tempted to pick up a replacement long block, than rebuilding it... Unless you can do the work yourself, replacement will likely be cheaper, and most certainly faster.
