My 2004 1500 5.7l Ram fuel pump won’t run
Old Sep 16, 2022 | 10:08 PM
Alex22's Avatar
Alex22
Default My 2004 1500 5.7l Ram fuel pump won’t run
I’ve tried jumping it and it runs strong but won’t run by itself or move fuel or pressure to the fuel rail when jumped what do I do
Old Sep 17, 2022 | 12:22 AM
95RAM360's Avatar
95RAM360
I’ve run into this a few times at my shop, ive just run a jumper wire to a keyed on vacant fuse point in fuse block, done it in Durango’s, dakotas, and rams, same thing, ram single jumper wire, but I wire in correctly to fuse block, I don’t splice it, everything soldered and shrink wrapped
Old Sep 19, 2022 | 03:58 AM
fj5gtx's Avatar
fj5gtx
So wait... you say it won't even push fuel to the rail when jumped? That is a confusing sentence...
Old Sep 20, 2022 | 04:39 AM
vietti2's Avatar
vietti2
it has a non replaceable filter inside it. it could be clogged. put a hose on the output and pour gas into the hose and with an air hose, blower the fuel lightly in and out .
see if the fuel comes out dirty from the filter...
mine in picture was clogged from charcoal canister
