P0308 P0172 Map Sensor Missing Wire
Old Nov 8, 2022 | 10:49 AM
brokenwings's Avatar
brokenwings
Default P0308 P0172 Map Sensor Missing Wire
Hi,
I recently purchased a 2003 Ram 1500 with 168,000 miles.
This is meant to be a beater that I purchased very cheap as is, the owner gave me a paper from an innova OBD2 scan tool that showed a code P0308, with a recommended fix of "repair engine wiring harness".
The truck starts and runs but it smells gassy. After replacing the battery I used a cheap chinese scan tool that I got off amazon and now I have P0172. I imagine the P0172 is just a generic rich code and the scan tool I have is just giving surface information, so its possible it will eventually throw P0308 again. and that is a more specific code related to the problem?
I checked the air filter and then went to clean the MAP sensor and noticed it has a wire missing
At this junction I'm assuming it's just running without a MAP sensor reading.
Would it be possible to just replace this specific connector, or would this indicate I need a new engine wiring harness?
Open to any suggestions as to where to start.
Thanks!
Old Nov 8, 2022 | 10:56 AM
P0308 is misfire on cylinder 8.
P0172 is fuel system to rich, bank 1. (cylinder 8 is on bank 2.)
What engine ya got?
Pretty sure the map should have three wires....... might wanna pull back the covering on the harness there a bit, and see if you can find that third wire.
Old Nov 8, 2022 | 11:08 AM
brokenwings
Ya from my preliminary googling it does sound like that connector should have a 3rd wire going to it.
Engine is 4.7L.
Good call on looking for the other wire.
Old Nov 8, 2022 | 11:27 AM
Yep, should be three wires.
Violet with white trace, Dark Green with Red trace, and Black with light blue trace.
