Truck wont start after break in
Old Dec 19, 2022 | 05:33 PM
Roaddawg61's Avatar
Roaddawg61
Question Truck wont start after break in
Someone was nice enough to break into my 2007 Dodge Ram 1500 2 days ago and bust out the steering console cover. Now the truck will not start. Everything powers up fine. I even tried to jump start it but lack of power not the problem. When i turn the key all lights light up and all looks good. When I turn key to start engine everythig goes dark. All lights off and nothing happens. Before i spend stupid money taking this to a shop r dealer does anyone have nay insight as to what may have happeed? Is there an antitheft system that needs to be reset? Thank you for your replies/
Old Dec 19, 2022 | 05:48 PM
Does all the power go out, and not come back on till you turn the key off? Was the ignition switch damaged?
Old Dec 19, 2022 | 06:01 PM
AtomicDog's Avatar
AtomicDog
Should this thread be moved to the 3rd gen truck forum?
Old Dec 19, 2022 | 06:02 PM
Yep. Takin' care of it now.
Old Dec 19, 2022 | 06:34 PM
jrsick's Avatar
jrsick
They probably removed your steering cover to get to the ignition starter switch. They disconnect the ignition starter switch from the key cylinder and start the truck with a screwdriver. We can help you fix this, just need a picture of the underside of your steering column with the cover removed.
