Upper control arm help
Old Dec 27, 2022 | 05:12 AM
5.9build's Avatar
5.9build
Default Upper control arm help
I have a 2007 ram 2500 5.9 Cummins rwd. It has been hell trying to find upper control arms and a lot of other parts. Id really want some adjustable upper control arms for a lift. Does anyone know what’s compatible with my truck,and would a heavy duty set of 1500 work for a 2500?? I’ve been searching for the longest time please help
Old Dec 27, 2022 | 09:28 AM
Do the 2500's actually use different control arms than the 1500's??? Compare part numbers and see.
Old Dec 27, 2022 | 10:01 AM
5.9build's Avatar
5.9build
I’m not sure I was hoping someone here knew it’s been a pain like no other lol
Old Dec 27, 2022 | 10:21 AM
Looking at the numbers on rock auto, 1500's from 06-08 and 2500's from 03-10 use the same heavy duty upper control arm.
Old Dec 27, 2022 | 10:33 AM
jrsick's Avatar
jrsick
I'd recommend discussing your setup with the shop that going to do your alignment. Control arms are adjustable, and there are adjustable ball joints you could install also.
