2002 dodge ram 1500 5.9l coolant leak.
Old Jan 2, 2023 | 01:14 PM
dunklehass14's Avatar
dunklehass14
Default 2002 dodge ram 1500 5.9l coolant leak.
i have a 2002 dodge ram 1500 4x4 5.9l crew cab(its the 3rd generation). i broke a thermostat housing bolt off in the intake manifold so i was giving a 2nd gen intake manifold everything is the same except the egr on the back of the 2nd gen intake manifold. Well i swapped the intake manifold with the one i was giving out new gaskets on new thermostat with gakset and housing, and new throttle body gaskets. after i hooked everything back up except the battery i went to fill the antifreeze up and notice im leaking pretty badly still. i havent started the truck up since it was parked before the intake manifold swap was done. im lost as to why im leaking so badly can anyone help? I will go back to the truck and try to get some pictures as where its leaking but all gasket from intake manifold to throttle body gaskets have been replaced already.
Old Jan 2, 2023 | 01:18 PM
Need to know where it is leaking from.
