Power Steering Low Pressure Hose Removal
Old Jan 18, 2023 | 08:24 PM
It looks like there is a hose clamp, and a compression clamp on there. If you remove the screw clamp, and cut the compression clamp, the hose should slide right off. If there is a bit of a flare, or the tubing is just larger in some fashion toward the end, just clamping the new hose on should be fine. It's a return line, so, you wouldn't think it was under a whole lotta pressure.....
Old Jan 18, 2023 | 08:41 PM
gsinclair's Avatar
gsinclair
Thanks. I put the screw clamp on to see if it would stop the leak and it appears to have virtually stopped it. I'm going to watch it for a while to see if that holds or not. If not, I guess I'll try what you said and just get a piece of hose cut. Can't figure out why that nut would not come out - but oh well. lol.
Old Jan 18, 2023 | 10:41 PM
aleekat's Avatar
aleekat
If you decide to cut the tubing, put some grease around the cut to catch the shavings.
Old Jan 18, 2023 | 10:43 PM
gsinclair's Avatar
gsinclair
Will remember that one. Thanks
Old Jan 19, 2023 | 06:37 AM
jrsick's Avatar
jrsick
If you are going to disconnect the hose vice remove, heyyou's suggestion to remove the clamps and pull the hose off is the way to go.
I recommend that you clean the entire area with engine cleaner, then dry it off and wipe it down. A clean area will help you isolate the leak and determine if your fix is leak-proof.
