Dodge Ram 1500 2003 4.7 246000 mi
Old Feb 27, 2023 | 02:33 PM
DodgeTheFatha's Avatar
DodgeTheFatha
Default Dodge Ram 1500 2003 4.7 246000 mi
Hello all! So recently my truck started to sound really bad 5000 miles from last oil change. I did the the oil change and upon start up it probably got a little worse. I did a little research and tried emptying half a quart of oil and replacing it with half a quart of atf , revving the engine at 3k for a few mins (get the oil pump going) and it may have gotten worse I ended up going to autozone and they said it was the crankshaft position sensor , as well as a spark plugs. I was a little skeptical but figured it wouldn’t hurt to replace. I did the job as well as replacing the oil with valavoline himi syn and the noise did not go away. First impression I figured something with the rocker arms, spring , or valve. Any help would be appreciated !!
Old Feb 27, 2023 | 02:36 PM
DodgeTheFatha
Default Video
Video
Old Feb 27, 2023 | 04:36 PM
Need to host your video elsewhere, then link to it here.
Welcome to DF!
Post your vid in the 3rd Gen Ram section.
Old Feb 27, 2023 | 05:19 PM
DodgeTheFatha
Default Video
Video
Old Feb 27, 2023 | 08:01 PM
Pull the valve covers, sounds like you spit out a rocker.
Old Feb 27, 2023 | 09:08 PM
DodgeTheFatha
I figured it had something to do with the valve. Any recommendations on where to get the rocker arms and springs ? im debating whether or not to replace all rocker arms depending on the price >.< thank you for your insight.
Old Feb 27, 2023 | 09:11 PM
Usually it's just the lifters that fail, and unless they are physically damaged, you can re-use the rockers.
