Brake Pedal to the Floor
Old Feb 27, 2023 | 09:51 PM
thelaminator's Avatar
thelaminator
Default Revised: Brake Pedal to the Floor
I have a 04 Dodge 1500 Rumble Bee. I replaced a brake line in front that rusted out. Unable to loosen the bleeder screws So I replace all calipers, bleeder screwson top. I bled FRONT and BACK lines several times and the brake pedal still goes to the floor. NO LEAKS. Any advice on how to fix this?
Last edited by thelaminator; Mar 12, 2023 at 08:20 PM. Reason: Additional info REVISED all 4 calipers bled and no leaks
Old Feb 28, 2023 | 09:23 AM
Are you bleeding the rears as well?
Old Feb 28, 2023 | 06:01 PM
Alex Medeiros's Avatar
Alex Medeiros
I was wondering if this could play a part as well...
Old Mar 1, 2023 | 09:56 AM
Always gotta bleed all of 'em.
Old Mar 4, 2023 | 07:57 PM
thelaminator
Front and back also bled
Old Mar 4, 2023 | 07:59 PM
thelaminator
front and back also bled
Old Mar 4, 2023 | 08:02 PM
thelaminator
front and back bled also
Old Mar 5, 2023 | 09:24 AM
Still have air in the system, or, a leak somewhere.
Old Mar 5, 2023 | 02:02 PM
racerxv6's Avatar
racerxv6
Agree with HeyYou, either air is still in the system or you have a leak. how are you bleeding them? Gravity bleed or is someone assisting you?
