Park lamps stay on
Old Mar 5, 2023 | 12:57 PM
Benwelds's Avatar
Benwelds
Default Park lamps stay on
Hi, I have a 2005 Ram 1500 with the 4.7 what I was wondering why my turn signal lights would be on all the time even after I shut off the truck. I was able to get them to turn off for a bit but they turned back on over night, this all started after I tested a winch on my battery, I’ve replaced bulbs, the relay, and I also looked for corrosion in the connections but there was nothing also with no broken wires. Any feedback would be appreciated
Old Mar 5, 2023 | 01:41 PM
aleekat's Avatar
aleekat
I tested a which on my battery???
Old Mar 5, 2023 | 01:54 PM
Benwelds's Avatar
Benwelds
The physical truck battery, thats right next to all the fuses
meant a winch, my bad
Old Mar 5, 2023 | 01:59 PM
racerxv6's Avatar
racerxv6
Might just be a fluke. but are all park lights on or just the rear...if it's just the rear could be the brake switch that sits up under the dash where the pedal makes contact. When you press the brake pedal it closes the circuit allowing the current to flow and power the lights. When you let off the pedal it opens the circuit and breaks the flow turning them off. Again only thinking if its the back lights not all lights. Other than that it's a grounding issue. Just gotta start tracing wires.
Old Mar 5, 2023 | 03:32 PM
Alex Medeiros's Avatar
Alex Medeiros
Do you have and LED or HID bulbs on your truck, or do you have stock Halogen bulbs?
Old Mar 5, 2023 | 03:33 PM
Benwelds's Avatar
Benwelds
Just Halogen
Old Mar 6, 2023 | 07:20 PM
aleekat's Avatar
aleekat
You never answered. All 4 parking lights?
Old Mar 6, 2023 | 07:36 PM
Benwelds's Avatar
Benwelds
yes all 4 are on, since that last post I cleaned some of the grounds and seemed to help it only came back once so far
