Random plug behind where radio is in 2002 ram?
Old Apr 10, 2023 | 04:09 PM
BlueDodge02's Avatar
BlueDodge02
Default Random plug behind where radio is in 2002 ram?
I took off the dash peice for the radio area and I see all the plugs for the heat and air, 4wd, etc but there is a random little plug that isn't pluged into anything. Just wondering what it is for?
It's right by itself below the tag? It's just plugged into a plastic piece? Anyone knows what that's fo?
Old Apr 10, 2023 | 04:52 PM
Probably for an option you don't have.
Old Apr 10, 2023 | 05:48 PM
BlueDodge02
It has just about every Option Available for the truck, do you have any idea what it could be for on the other model?
Old Apr 10, 2023 | 05:52 PM
BlueDodge02
Just did a little research and I'm 95% sure it's for the airbag switch how some of them you could turn off the passenger airbag.
Old Apr 11, 2023 | 08:31 AM
dodgetruck2's Avatar
dodgetruck2
3rd gen regular cab trucks only had airbag shutoff lower right on the dash. I would agree with the above, whether or not you could plug the switch in and use it on all models I'm not sure.
Old Apr 11, 2023 | 11:25 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Airbag shut off switch for reg cabs only. Since it doesn't get used it gets plugged into a blank on the backside of the center bezel in quad cabs. Don't screw with it since that ties directly to your SRS.
