Need help with hydro booster or master cylinder
Old 05-16-2023 | 05:53 PM
ruvkaz's Avatar
ruvkaz
Default Need help with hydro booster or master cylinder
Hello, can anyone help me, so basically I replaced all the calipers and flushed all the brake fluid… why I’m having now and before is, when I press the brake pedal nothing happens 3/4 of the way and then the rest of Pedal is hard, and when I release its slow to return, so I don’t know if I need to replace the master cylinder or hydro booster
Old 05-16-2023 | 06:44 PM
Alex Medeiros's Avatar
Alex Medeiros
Did you flush both the front and rear brakes?
Old 05-16-2023 | 08:07 PM
ruvkaz's Avatar
ruvkaz
Yes, before I forgot to mention I changed the abs module, and then flushed all the brakes 3 times in a row good steady stream coming out and no bubbles, so it comes down to these things
- either change the master cylinder
​​​​​​- change the hydro booster
- don’t k ow if I need to flush the abs module since I’m having good flow and no bubbles
Old 05-18-2023 | 03:56 AM
DanielSchexnayder's Avatar
DanielSchexnayder
Have you resolved it? Have you resolved it? if not then, replaced the callipers and flushed the brake fluid, if you're still experiencing issues with the brake pedal. If still not fixed then you should get p[rofessional help. Although I am looking for a booster cylinder have some money problems, Recently I accidentally visited an online casino reviews site https://casinosanalyzer.com/casino-b...egascasino.com which shares some grande vegas casino promo codes and get all the benefits and earn more money. And about your problem yes, it's possible that there could be an issue with either the master cylinder or the hydro booster.
Old 05-18-2023 | 10:58 AM
ruvkaz's Avatar
ruvkaz
No I haven’t solved it, also I changed out the abs module, don’t know if that affects anything bc I flushed the brake fluid through the calipers and everything seemed good, just slow brake pedal return
Old 05-18-2023 | 12:11 PM
Have a look at the brake pedal pivot. Make sure that feller isn't binding.
Old 05-18-2023 | 12:20 PM
ruvkaz's Avatar
ruvkaz
I did and doesn’t look like it’s hiding or off everything is normal and no leaks anywhere
Old 05-18-2023 | 12:21 PM
Disconnect the brake rod from the pedal, move the pedal, how does it feel?
Old 05-18-2023 | 12:47 PM
ruvkaz's Avatar
ruvkaz
The brake pedal feels normal it’s loose and not stiff, easy to move
Old 05-18-2023 | 12:50 PM
Ok, so, that ain't it....
Brake or ABS lights on? Does it feel like you are getting any assist from the hydraboost? Might not be a bad idea to separate the master cylinder from the booster, and see if you have fluid in there... (leaking from one, or the other....)
Quick Reply: Need help with hydro booster or master cylinder
