No power to fuses
Old Jun 11, 2023 | 01:00 PM
hoss_actual's Avatar
hoss_actual
Default No power to fuses
Hey all, my 03 1500 with the 5.7 has no power to fuses 32 through 38. No speedo, abs and brake lights are on, no ac, no cruise control, airbag light is on. I've checked the connections at the bottom of the IPM and cleaned any corrosion I found, no dice. Any ideas?
Old Jun 11, 2023 | 01:28 PM
Looks like most of those are powered from the ignition switch.
Old Jun 11, 2023 | 01:34 PM
hoss_actual
True, I didn't even consider the ignition switch. Any ideas on where I should start checking?
Old Jun 11, 2023 | 01:52 PM
You can find wiring diagrams for your truck here. Yes, it's a russian site, but, I have been using it for a couple years without issue. See which wire from the ignition switch is supposed to be powering those fuse, and see if there actually is any power on the terminal of the switch.
Old Jun 11, 2023 | 02:46 PM
hoss_actual
Oh lord there's a lot here haha. I'll give it a look through, thank you
Old Jun 11, 2023 | 05:15 PM
Look in the power distribution section, I think it was sheet 3 that had those fuses.
