key chime stays on
I have a 2004 2500 I don't know history on, it had headlights hot wired when I got it. I have replaced ignition switch and key switch, fuse box and attached module, now lights work as should. Key buzzer chime stays on when key pulled and kills battery overnight. Working the tilt column seem to effect it but not all the time. I have cleaned all the grounds I could find, new battery. any ideas?
I replaced a ign switch and it worked for a week, changed the steering column angle and it crapped out again YAY!
Did you get yours sorted ?
