46re dodge ram 5.9
Old Jul 14, 2023 | 07:05 AM
Spooderboss2000's Avatar
Spooderboss2000
Default 46re dodge ram 5.9
So yesterday i was driving home and as i was on the highway the truck wouldn’t shift and would stay in 2nd gear i suppose i was also low on gas idk if that has anything to do with it but whenever i’d let off throttle it wouldn’t do anything and stay in gear and it made it climb mph faster but i didn’t want the trans to overheat idk if it’s a limp mode thing but, when i would flip OD on then off it would seem to fix it for a bit till it would be stuck in gear, i also tried to over take and when i floored it it downshifted and just redlined didn’t even grab a gear at all i was also on a slope though, after i stopped at a light it seemed to start shifting normally
Old Jul 14, 2023 | 07:21 AM
Getting any codes?
Old Jul 14, 2023 | 07:23 AM
Spooderboss2000
Getting any codes?
I checked the pcm codes and i haven’t gotten any codes only codes i’ve had for over a year is just the p0601 but the trans worked fine even with the code being there
Old Jul 14, 2023 | 07:25 AM
P0601 is a memory checksum error, generally implies a failed PCM. So long as that code is present, doing more troubleshooting is pointless.
Old Jul 14, 2023 | 07:27 AM
Spooderboss2000
so that could basically be the reason why at certain points the trans starts tweaking correct?
Old Jul 14, 2023 | 07:31 AM
Yep. That code says the PCM has a serious issue. Trouble is, it can manifest itself in any number of ways.... from annoying little problems, that you can ignore (for a while) to total system failure.
Old Jul 14, 2023 | 07:41 AM
Spooderboss2000
Okay sounds good i’ll be ordering a new pcm this week, do you have any recommendations for company’s or sites to order a flashed pcm?
i was thinking of using a junkyard one but i heard that if u have a skim it won’t work
Old Jul 14, 2023 | 07:45 AM
Yeah, PCM needs to be flashed to the correct VIN for everything to work right..... I personally don't have a recommendation, though, a member in the 2nd Gen section has had success with SOLO PCM..... If one of your local parts stores can get you one at a reasonable price, that would be the preferred route though. That way, if there is a problem, you can talk face to face with a live human being.
Old Jul 14, 2023 | 08:14 AM
Spooderboss2000
Would a 2000 pcm plug in with a 2002 truck the 2000 has the same engine and transmission
Old Jul 14, 2023 | 10:39 AM
fj5gtx's Avatar
fj5gtx
Match the number on your pcm to the replacement. I put a used one in my 04 1500, ordered from ebay. Had the dealer program it. .
