Redish brown color on oil cap
Old Jan 6, 2006 | 05:20 PM
eltupac's Avatar
eltupac
Default Redish brown color on oil cap
I changed the oil on Monday, 10200 miles and when I opened the cap I found this brownish redish color fluid on the bottom.
Anybody seen this before, is it normal?
Old Jan 6, 2006 | 07:57 PM
osteodoc08's Avatar
osteodoc08
Default RE: Redish brown color on oil cap
Did it wipe off or was it more like discolored plastic? Need more info, please.
Old Jan 6, 2006 | 08:56 PM
CarGuyOhio's Avatar
CarGuyOhio
Been posts on this before. Although I do not recall if it was brown, yellow or white. But many, including me, have seen it on our caps. Just wipes off. I think I recall someone saying moisture can cause it.
Old Jan 6, 2006 | 11:38 PM
osteodoc08's Avatar
osteodoc08
That's why I was asking. I've seen plastic caps that have condensation on it, esp starting this time of year and I've seen them with what looked like old degraded plastic with a brown patina that couldn't be wiped off. Both nothing to worry about. When you get milky oil is when you should worry
Old Jan 9, 2006 | 11:23 AM
eltupac's Avatar
eltupac
Yeah, it wipes off. Thanks for the responses. I guess I wont worry until I see a milkshake
Old Jan 11, 2006 | 03:20 PM
motorhead426's Avatar
motorhead426
There's a few mopar engines that have similair issues to moisture near the oil cap. Have any of you seen the plastic insert for the 4.7 engines? There is a little funnel shaped plastic piece that inserts to the oil fill neck. This is because without it, you'll find a milkshake looking foam on the bottom of the oil cap. Not sure why it happens, but Chrysler started installing these on the 4.7's soon after they hit dealer lots. I have noticed some moisture on the fill cap to my Hemi ('05), but not near as bad as some of the 4.7's I've seen.
Old Jan 12, 2006 | 03:54 PM
steeringcolumn's Avatar
steeringcolumn
ORIGINAL: motorhead426
I've got the same thing,the stuff eventually starts to build up!
Once you figure out the "Little funnel shaped plastic piece"comes out,It sure is easier to add oil!!![8D]
Old Jan 8, 2007 | 05:57 AM
sixdoubleo's Avatar
sixdoubleo
I noticed the same thing today....in fact I posted a message about it and included a picture. Mine had a small amount of water in the cap too. Is that was yours looked like?
https://dodgeforum.com/m_666146/mpag.../tm.htm#666149
Old Jan 8, 2007 | 12:58 PM
Jetpig's Avatar
Jetpig
It is completely normal. Condensation. Mostly comes from short operating times. When the enginedoes notreach full temp, the moisture inside the engine initiallyturns to vapor but does not get hot enough toevaporate out of the system. When you shut it down and the engine cools, the vapor condenses on the upper parts of the engine.
