Strange coolant temperatures - what might be the cause? 5.7 HEMI
Old Jan 4, 2024 | 05:07 PM
GrossmeisterB's Avatar
GrossmeisterB
Default Strange coolant temperatures - what might be the cause? 5.7 HEMI
Cheers everyone,
just got back from a 1000 mile road trip, everything was fine with my truck.
But today I did some work (replaced some control arms and ball joints), when driving home I had the OBD live data on my screen.
I noticed the coolant temperature rising up to 108°C / 226°F while driving along (20/30mph). I never noticed such high temperatures.
I kept driving as I was close to my home. Temperatures were dropping again then, down to 94°C/201°F. I let it idle in my driveway and temperature was stead at 94C/201F.
Is this anything to worry about? Maybe the thermostat giving up?
Only things I changed recently is the drive belt with the tensioner.
Thanks a lot!!
Old Jan 4, 2024 | 05:11 PM
If you started with a cold engine, that isn't unusual.
Old Jan 4, 2024 | 05:15 PM
GrossmeisterB
Yeah, started cold like 3 miles before that.
What is the reason for that?
And thank you for always answering the questions, even if they are somewhat stupid sometimes.
I am really happy about that!
Old Jan 4, 2024 | 05:42 PM
No such thing as a stupid question here.
There is probably some law of thermodynamics that would explain it, but, damned if I know what it is. It's just behavior I am used to seeing. If it runs hot like that for longer than a few minutes though, I would be tempted to swap the thermostat. I don't think its necessary yet at this point though.
Old Jan 4, 2024 | 06:15 PM
GrossmeisterB
OK, maybe it happened before and I just didn't notice. But will now keep an eye on it for sure.
Thanks for the explanations!
Have a great day and many greetings from Germany
Old Jan 14, 2024 | 09:50 AM
GrossmeisterB
I nearly forgot about it, but today I noticed the gauge going up and down again and checked via OBD.
So, no real matter how I'm driving, temperature goes from 92°C/198°F to about 104°C/219°F and back down.
Even when going steady at 60mph.
I think I haven't had that before?!
So it seems like the thermostat is not operating like it should?
Old Jan 14, 2024 | 10:07 AM
They aren't really expensive, could just replace it, see if anything changes. (no "safety stats" though, those are guaranteed to fail.)
Old Jan 14, 2024 | 10:42 AM
GrossmeisterB
Yeah, maybe that's the best idea. Will have to change over my coolant anyway, so can do it all together then.
Will a "Gates" thermostat with 203°F be fine? Like " GATES34053S " ?
Old Jan 14, 2024 | 12:24 PM
If that is the stock temp, then sure. Gates generally has a pretty good rep.
Old Jan 15, 2024 | 10:00 AM
fj5gtx's Avatar
fj5gtx
How long does it take to change?
