2008 4wd Dodge ram 2500 drive shaft problems
Old Jan 10, 2024 | 12:15 AM
the1whitestallion's Avatar
the1whitestallion
Default 2008 4wd Dodge ram 2500 drive shaft problems
4wd drive shaft problem is that I have replaced it twice already and it just broke again inside that ridiculous knuckle it has. Was just wondering if others have that same problem and if there is a fix for it.
Old Jan 10, 2024 | 10:12 AM
Front or rear shaft? Is it a CV joint?
Old Jan 10, 2024 | 10:16 AM
the1whitestallion
It's the front shaft from the transfer case with that weird knuckle at the transfer case end. All have failed in that knuckle in the same spot.
Old Jan 10, 2024 | 10:22 AM
fj5gtx's Avatar
fj5gtx
Is your truck lifted?
Old Jan 10, 2024 | 10:50 AM
the1whitestallion
Yes it is I'm pretty sure. Tires are 35s and don't rub so most likely yes. Previous owner lifted.
Old Jan 10, 2024 | 11:22 AM
Probably need to get a high angle shaft, or re-clock the t-case so it's lower.
Old Jan 10, 2024 | 12:08 PM
the1whitestallion
Thank you for the advice I'm going to look into that.
Old Jan 11, 2024 | 10:42 AM
fj5gtx's Avatar
fj5gtx
You could take it to a off-road specialty shop and have them identify how much lift (maybe manufacturer) and check it over for correct installation. They are typically well versed on problems associated with lift kits and how to address those properly.
Old Jan 23, 2024 | 04:47 PM
the1whitestallion
Default Pretty sure I figured it out
When taking apart the u-joints I noticed that the guy who rebuilt and messed up my 68rfe recently took apart the u-joint at on end and didn't mark the orientation of the shaft. Put it back in 180 degrees backwards. I noticed a slight vibration but thought initially it was my tires and did not discover what it really was until it was too late after going 700 miles. Even when you get a new shaft if needed pay close attention to any slight vibration
