water leak
I have a 2004 dodge ram 2500 with a water leak. it appears to be leaking around back passanger corner near bed of the truck. not the vents. don't think it is the third brake light, new gasket just in case. i am guessing the rear non opening window in the back. it gets wet along the rail under the plastic trim pieces around wheel wells and the tool spot under the back seat. also along the front passanger floor board near the door. anyone else with this problem and possible solution?? any help appreciated.
Since you're dealing with a 2004 Ram 2500, this topic should be moved to the 3rd gen section. ![Icon Twocents](https://dodgeforum.com/forum/images/smilies/icon_twocents.gif)
https://dodgeforum.com/forum/3rd-gen-ram-tech-65/
The following users liked this post:
nursematt2022 (01-24-2024)
