Cylinder 8 misfire p308
I can’t for the life figure out this misfire on my 08 with the 4.7 v8 (flex fuel) When I start it up the car misfires but after it gets to operating temperature it runs fine. I started by changing out both spark plugs. Swapped coil packs, replaced the fuel injector and did a compression test. During the spark plug change I noticed it had oil on it. I did remove the valve cover and cranked it to see if the valve lifter moved freely and it did. I should have replaced it when I had the cover off looking back now. I’m not really sure what to do next.
