no dome lights
Old Feb 10, 2024 | 11:06 AM
that3rdgenguy's Avatar
that3rdgenguy
Just to be clear, is it JUST the dome lamps that aren't working?? (they aren't manually switched. just controlled by the cluster.)
yes only the dome lights( the overhead lamps) and the on above the rear seats, don't won't come on if i press them or open the doors
Old Feb 10, 2024 | 11:12 AM
Need to check the brown wire, Pin 3, Connector 3, at the back of the cluster (I think it is a 9 wire connector?), see if you have power there. Should be hot at all times.
Old Feb 10, 2024 | 11:14 AM
that3rdgenguy
i will remove the cluster and check, but it's strange since the dome has power to 2 wires of them 3...
