no dome lights
Old Feb 10, 2024 | 09:57 AM
that3rdgenguy's Avatar
that3rdgenguy
Default no dome lights 03 ram gen 3
hello guys,
Im having an issue with my truck the dome light won't come on either by pressing them or opening the doors.
I checked if they got power and they do, the fuse isn't blown either.
Could someone help me im freaking out.
Thanks
Old Feb 10, 2024 | 10:07 AM
What are you driving?
Old Feb 10, 2024 | 10:08 AM
that3rdgenguy
03 ram 3rd gen
Old Feb 10, 2024 | 10:35 AM
Looks like they all get power from fuse 17 in the fuse block under the hood. They are 'switched' via the instrument cluster though, which provides the ground path for them.
Old Feb 10, 2024 | 10:37 AM
that3rdgenguy
the fuse is good though, does it have something to do with the cluster?
Old Feb 10, 2024 | 10:45 AM
Yes. The various switches (doors, etc) do not directly control the lamps. They simply clue in the cluster that a door is open, or some such, and then the cluster decides whether it really wants to turn the light on or not. Even the reading lamps, the switches complete the circuit to the cluster.... not to ground. Cluster grounds at G301, left front of body..... Where exactly that is, I don't know. Does the cargo lamp work? Or the glove box light?
Old Feb 10, 2024 | 10:47 AM
that3rdgenguy
yes everything works just fine except for the dome light the front and the rear... i really don't have any more clue on what to dig in to
Old Feb 10, 2024 | 10:54 AM
Are the bulbs good?
Old Feb 10, 2024 | 10:56 AM
that3rdgenguy
Are the bulbs good?
yes they are
Old Feb 10, 2024 | 11:03 AM
Just to be clear, is it JUST the dome lamps that aren't working?? (they aren't manually switched. just controlled by the cluster.)
