Can someone help me identify a part?
Old Feb 14, 2024 | 12:07 PM
ryblmc's Avatar
ryblmc
Default Can someone help me identify a part?
I have a 2008 3.7L Manual SXT. I have found varying results in exactly the which gasket I need to replace this oil leak.
Old Feb 15, 2024 | 02:31 PM
FabricGATOR's Avatar
FabricGATOR
Default Clean it up 1st
I can't right identify what I am looking at there
I have a 5.7 so there is that difference...
Myself, I would clean up the stain and observe where it originates.
A can of gunk engine degreaser and a strong stream of water (you could go at it with a wire brush to loosen the grease a bit)
Then check it after running it. If it has been a long time oil 'seep' and it is not making a lot of oil stains on anybody's driveway, I would just leave it be.
While it is not 'perfect' unless it is a heavy oil leak source, you may create more problems than you might be fixing.
After you clean it up and can view where a gasket MAY be leaking (seeping) then maybe a light dusting with baby powder may reveal the source more rapidly.
Myself, I use a welder product called 'Spot Check' and use the step C 'developer (a spray on aerosol, powder) that will show where the oil is coming from.
Let us know what you find and what you end up doing, how it goes...
More motor vehicle problems may be caused by over maintenance than are actually solved. It was near perfect when it left the factory...
