2002 5.9 Magnum...codes and shuddering...help
I love this truck for our ranch, but if I try to go get hay or anything, it will totally act up.Yesterday I went 3 miles to mailboox, and it threw 3 codes:
P0340: No Cam Signal At PCM
P0306: Cylinder #6 Misfire
P1391: Interm Loss of CMP or CKP
Background... We got he truck 6 years ago with 98k. Ran fine, but it took longer and longer to start. Everyone said was a pump issue. if it sat, the fuel would drain back into the tank....not a big deal. it ran fine for everything we did once it started (usually 2 or 3 sets of 2 sec cranks). Then we had trans and motor problems. It was in the shop for almost 2 years off and on. The mechanic kept returning it saying its fixed. The trans is ok not (replaced) but now I have this stuttering issue. IT also burns some oil, but that isn't a big dead. The truck has like 130k on it and I would love to keep it. Any ideas?
Rick
Rick
I can't find it at autozone but i found a link on amazon above
Like this. You want a genuine mopar sensor if you can find one.
Ok I got that, replaced it, cleared codes...I drove it for a while and no more codes, but that studder thing comes in when im going faster. and I am not sure if its the trans or like a loss of power from something. any idea what I can try next?
What conditions are present when you feel the studder? (vehicle speed, what gear the trans is in, etc.) Still getting misfire codes??
Trending Topics
No codes now.. when im on my ranch its fine. but when i get on the highway and put some gas to is, it like studders. just for a second then moves but its usually when there is a load on the motor or im giving it gas. it will happen intermittently when driving. usually like every few seconds for like a bit of a second. I could actually drive it like this but i feellike one of the times its going to just stop. i cant tell if its something with the trans or with the motor. no weird sounds. but i check fluid levels and they are fine. seems to happen around 40-50mph the most
