2003 Dodge Ram 1500 St 4.7
Old Mar 21, 2024 | 03:09 PM
Johner57's Avatar
Johner57
Default 2003 Dodge Ram 1500 St 4.7
When trying to start whether its cold or hot I need to press the gas pedal 3 times and I try to start and it just turns over, then I pat the gas pedal again and it starts. what could be the problem?
Old Mar 21, 2024 | 04:02 PM
Low fuel pressure, bad TPS, or Pedal Position sensor, or a host of other things. Does it run ok once it starts? Any codes?
Old Mar 21, 2024 | 07:43 PM
Johner57's Avatar
Johner57
Once it is started it runs great and no other codes
Old Mar 22, 2024 | 06:01 PM
Is that one throttle by wire?
Old Mar 23, 2024 | 12:45 AM
Prismatic's Avatar
Prismatic
Nope throttle cable to the throttle body.
Old Mar 25, 2024 | 07:18 AM
DJG11704's Avatar
DJG11704
Default Fuel bleed back 👍
Next time you go to start it after it’s sat all night, Turn the key on and let the fuel pump run for 10 seconds. Do that 3 times before you try to turn it over. Don’t touch the gas pedal 👍 if it starts, you have a weak fuel pump.
A. tps will make erratic driving issues when driving,👍. Ask me how I know???
