Transmission trouble
Old Mar 24, 2024 | 04:07 PM
Joe Nafziger's Avatar
Joe Nafziger
Exclamation Transmission trouble
So I have a 2006 ram 1500 Hemi 4x4 short box regular cab Automatic With 545RFE in it. It is a toy but the transmission recently gave up 3rd gear. I have a transmission out of a 2011 hemi 4x4 long horn it is a crew short box if that matters, Automatic as well. can I use this transmission? It is a rebuild from a truck that was parted out. basically I want to know what it would take and if it is worth it or not. If it cant be done what years of transmission should I be using? Thank you for the help
Old Mar 24, 2024 | 04:19 PM
What trans was in the 2011??
Old Mar 24, 2024 | 04:25 PM
Joe Nafziger
545rfe
Old Mar 24, 2024 | 04:34 PM
Solenoid pack is different in 2011. Won't interchange as it sits.
Old Mar 24, 2024 | 04:43 PM
Joe Nafziger
Can i change the solenoids packs or are they completely different?
Old Mar 25, 2024 | 09:07 AM
The newer solenoid pack has one less solenoid, supposedly, you can swap in the correct pack for your year truck, and it will work. But, I have never done so, just what I am reading on the internet..... so, ya know it just has to be true......
